goerend $650 converter
Postby Firstgen1 » Sun Jun 28, 2009 5:03 pm
does any body use the goerend 650 dollar converter? if so how do you like it, how much did it lower rpm,
if you dont have this converter he said it lowers stall speed 500 rpm, what stall speed does that put me at acording to signiture
does that put me near 1600 rpm?
thanks :lol:
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby SNOOT » Sun Jun 28, 2009 5:45 pm
Your boost may drop a couple pounds your truck will run cooler and it will pull harder.
I have had this converter for about a year now with good results.
1993 W350
SNOOT
Postby Bad93Cummins » Sun Jun 28, 2009 6:31 pm
That's the one ill be ordering shortly! along with a transgo shift kit.
Bad93Cummins
Postby peobryant » Mon Jun 29, 2009 7:30 am
Anyone ever use the $950 converter?
When I get my tranny rebuilt, thats the converter I want to put it in.
Either that or get a built 47RH, with Goerend parts. 8)
