Twins sizing?
Twins sizing?
Postby DoWhat? » Sun Jul 19, 2009 8:52 pm
I'm looking to build a set of twins. I want to use my WH1C with the stage III 60mm comp and a 12cm wastegated turbine side over a HT60 with the 23cm exhaust side. Does that sound like a feasable setup? Is there anything to gain by going to the 28cm exhaust side on the HT60?
I jsut need a little guidance... its my first set of twins...
-91 W250 day cab 5 speed
strait pipe, monkey pump, big tires
-96 Ford F-250 PSD
strait pipe, big injectors, tunes
DoWhat?
Postby Begle1 » Sun Jul 19, 2009 9:19 pm
You probably want the smaller housing on the second turbo, and might need an external wastegate.
Postby JQmile » Mon Jul 20, 2009 4:20 pm
Sounds like one heck of a quick-spooling setup to me! If you're not spinning a ton of rpm (like 4000+) you should be fine.
JQmile
Users browsing this forum: No registered users and 76 guests
