VE pump carnage (pics inside)
Postby Crossy's son » Tue Nov 10, 2009 5:36 am
Well i had the old "bad" 93 pump up on the bench with "boostedve" and removed the throttle linkage assembly and found that the throttle shaft spun effortlessly 360* ... immediately i thought "the gov. spring broke".
Found this- Image
what we found was the area where the pin rides was SO warn out and thin that it wasn't doing its job anymore..theres no doubt in my mind that little peice of metal is as thing OR THINNER than an aluminum mountain dew can....
thought i'd share. LOOK AT THIS WHEN YOU HAVE YOUR PUMP TOP OFF!!!
I guess that makes sense, the PO said he was driving it and it just shut off and wouldn't restart.
Brandon
90 D250 727 3.07's 227k miles
Crossy's son
Postby Ace » Tue Nov 10, 2009 7:19 am
More evidence of the need for fuel lubricity - or lack thereof.
Postby PToombs » Tue Nov 10, 2009 6:16 pm
Ace wrote:More evidence of the need for fuel lubricity - or lack thereof.
Not really, that arm is supposed to be solid to the shaft. ;)
