big exhaust
big exhaust
Postby 1dumrednek » Tue Dec 15, 2009 6:18 pm
im finally gonna put an exhaust system on this truck. ive been repeatedly told by exhaust shops that 4 inch cant be done on my truck. i know they're wrong. im just looking for some advice on how to do this.
i was thinking of coming 4 inch off the turbo and down and then going outside the skid plate with 5 inch and straight back to the stack. i know that it will be hanging below the frame but i dont think it should be a problem. i also know i dont need 5 inch but hey i like the sound 8) i was wondering too of id be better off buying the 4 inch down pipe or if i should just get the 4 inch flange and rig my own down pipe? then i wanna roll it up into a 8 inch mitre cut stack placed in line with the turbo.
think it'll work, any advice?
A.J.
91.5 Power Ram w250 LE 5spd reg cab... totalled... again
2002 2500 laramie slt plus sport, nv5600, MBRP 4" straight pipe, edge juice w/ attitude, DC1 rims, kelly fierce attitude M/T
1dumrednek
Postby dpuckett » Tue Dec 15, 2009 6:32 pm
Rule #1- local exhaust shops dont know crap about diesels, normally. There are exceptions.
#2- It has been done by plenty of people, both here and on other boards. I once built a 4" turbo back system, but it was on a 2wd. Plans are for one in the future on my W250, as the wife wants to keep it a while.
DP
Postby jwatso8 » Wed Dec 16, 2009 6:01 am
1dumrednek
i got a D250 with a 4" down pipe, it's tight. then runs 4'' to the bed, were it goes into 5" stacks. :lol: i got my down pipe form sourceautomotive.biz check them out. its kind of pricey. it was $209 plus $40 to ship, but its worth it to me on time saved trying to make one. they also sell parts for twin turbo set ups. :mrgreen:
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby Ace » Wed Dec 16, 2009 7:26 am
I vote make it yourself if you can weld. That way you save some money and can make it fit however you want. Don't overlook the bell housing mount. It's easy to skip if you're in a hurry, but that's what keeps it together up front.
Postby ford69557ci » Wed Dec 16, 2009 10:12 am
On my other w250 I had a 4" dp that went into 5" before the cross member 4" is tight but will clear. To run 5" ya gotta take the cross member brace out and modify it or start the 5" after the cross member.
ford69557ci
Postby SNOOT » Wed Dec 16, 2009 12:33 pm
4" to 5" system.. lol with a 7" tip..
http://www.youtube.com/watch?v=rz0cLOvsd3E
1993 W350
SNOOT
Postby unixcowboy » Wed Dec 16, 2009 12:38 pm
4" to the turn under the cab then 5" to the 5" stack
http://www.cumminsforum.com/forum/attac ... -stack.jpg
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby SNOOT » Wed Dec 16, 2009 1:52 pm
Stock D/P
4" D/P and 62 turbo
1993 W350
SNOOT
