1: What makes the IP internal pressure build up? Is it that little vane pump?
2: At what INTERNAL (not inlet pressure) does the case crack at?
3: Whats the minimum internal pressure needed to keep the IP running?
This has something to do with a delete and one of these puppies....
http://www.summitracing.com/parts/AEI-17140/
And what injectors do I need? 6x12's?
