see I will find a goos uses for those turbos
even if a gokart get one
Bschwarzli wrote:
Care to elaborate on what happened?
Soot builds up on the vanes if not used heavily over the cource of a few weeks, then the vanes started to bind, then crunch.
This could be caused by DPF related things, but wither way, was told that many of the early turbos that could not be cleaned before breakage, were just sold off on places like ebay.
IRoss wrote:If your seeing 1200 degrees on 'decent hills' in ontario your gonna want to have your fuel pin turned to the shallow side by the time you hit the crowsnest pass in alberta...I live between two of the big passes in the kootenays and I pretty much keep my fuel pin on the shallow side with my stock turbo..I've had smaller exhaust housings, but I find for going a decent speed up the mountain passes the 18cm is where its at for me...with my camper its 4th gear the whole way up, 2600rpm, empty i can run 5th at around 1200deg (130kph), 2400 rpm, I dont like to have to go slower just because Im overfueled...where ya goin?
