by Remps » Fri Feb 25, 2011 1:33 pm
I'm thinkin 150 psi, for a dual feed setup. A tee and check valve to the return, and a case pressure gauge plumbed into the shutdown solenoid hole. It`d be a secondary fuel system, and would only activate when case pressure dropped below a set pressure under load. It probably wouldn`t be of much use without big injectors of course. I haven`t seen an electric pump that is rated for more than 100 psi though.
