by 92strokersmoker » Fri Apr 15, 2011 11:53 pm
I just clocked my turbo tonight after running it with the wastegate and a boost elbow gettin 35-38lbs. Now that I reclocked and went with 3 inch IC tubes, I can only MAX at like 20-21. I wired the wastegate also. Kinda not liking this low of boost seeing as how it seems more boggy and EGTs run significantly higher (i can peg 1200 in 3rd where before Id be lucky to get 800) I thought about taking my star wheel back down to get more fuel with less boost but that dont fix my high egt numbers or low boost. What can or should i do. Any MAJOR problems with welding the wastegate shut other than not being able to use it again? Ill be checking my boots for leaks tomorrow. But I want that 35lbs back!
92 w250 NV4500, Denny T stage II, HE351, 5x.012, FPS maxed, 3200 spring, 1/4" timing bump, ALL guages, Carter fuel pump. And some more
