32 spline or 35?
32 spline or 35?
Postby RATROD92 » Fri May 20, 2011 11:28 am
I didn't know where to post this....I am looking at trac locks on ebay and wanted to see if anyone knows what a 1992 dually dana 70 rear is? 32 or 35 spline....I need to purchase one.
Thanks
James
92 D350 shortened 2 feet, 56 Ford F100 Cab, VE Pump maxed 12mm, Denny II, PDI exhaust manifold, Silver Bullet 64/74/14, SCHEID 6X.016's, 5 speed Getrag, 400 horse clutch, 3.54:1 rear, Air Dog II 165, Aluminum Radiator, Pump to head, 3800 R.P.M. spring...Puts a smile on my face when its lit....
RATROD92
Re: 32 spline or 35?
Postby Tacoclaw » Fri May 20, 2011 12:26 pm
From what I've read, you can tell by the nuts that hold your axleshaft in. If you've got the little conical ones that sit back in the flange, you've got 35 spline axles.
Postby huntinguy » Fri May 20, 2011 5:31 pm
Right! If the axle shaft is held on with bolts it's a 32 spline. If you have studs and nuts it's 35.
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
