1/4 mile et
1/4 mile et
Postby c12h26 » Wed Aug 01, 2007 6:17 pm
what is the quickest 1/4 mile et for a VE
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Postby Rampower » Thu Aug 02, 2007 8:07 pm
Kta did 13.75. I did 13.80. But KTA went 110 mph, and I did 94 mph. I think KTA has the title so far. But I havent heard from everybody yet.
Tim.
92 ext cab 4x4. HT62-14, 4" straight pipe, BHAF, O-ringed, Haisley head studs, Ported head, exhaust, and turbo. Fuel pin, 4,000 gov spring,
Rampower
Tim.
Rampower
Postby gman07 » Fri Aug 03, 2007 10:31 am
I think there's someone on DTR who went in the lower half of the 13's with a 2wd and slicks (and the stock auto).
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby 90firstgen » Fri Aug 03, 2007 2:50 pm
Yeah I don't remember who it is but I believe it was with POD's and a 35/40 hybrid. And the auto of course
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby Begle1 » Fri Aug 03, 2007 2:59 pm
Wow, really? He's my hero.
Do you know what threads that was covered in?
Postby 90firstgen » Fri Aug 03, 2007 3:37 pm
I've just seen it in their signature
3200 Spring
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
Stan's 4"
90firstgen
Postby gman07 » Fri Aug 03, 2007 5:28 pm
gman07
Postby 2muchtq » Fri Aug 03, 2007 5:35 pm
13.34 @ 99.5mph.
Thats not to shabby!!!!!
2muchtq
Postby GLHS » Fri Aug 03, 2007 8:39 pm
Whad'dya mean an auto of course? :)
GLHS
Postby Begle1 » Fri Aug 03, 2007 10:58 pm
What are the odds that a 5-speed guy would post the exact same time... :roll:
Really, I'm surprised by both numbers.
Postby 2muchtq » Fri Aug 03, 2007 11:01 pm
Hmmmm..........
Are we going to start asking for timeslips around here??? :lol:
Hopefully Rampower will post some decent numbers tomorrow. (He's still #2 only BTW)
2muchtq
Postby 90firstgen » Sat Aug 04, 2007 5:55 pm
GLHS wrote:Whad'dya mean an auto of course? :)
HAHA it sure makes it easier to get that fast! Nice mods btw. Ever dynoed?
EDIT: woops! I now see your numbers. Very nice! Very very nice!
3200 Spring
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
Stan's 4"
90firstgen
Postby rbrettctd » Sat Aug 04, 2007 6:03 pm
That cant be stock transmission. I ran the 727 for 4 years and never broke 83mph in it, not to mention I dont think the 3.07s would have the get up off the line for a low 13. Not saying I doubt him, but hes gotta be running the 518 or gear vendors.
Randy
rbrettctd
Postby 90firstgen » Sat Aug 04, 2007 6:12 pm
I kind of figured he had a built auto
3200 Spring
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
Stan's 4"
90firstgen
