Injector nozzle size?
Postby Mark Nixon » Thu Apr 07, 2011 2:00 pm
I have some injectors here with a nozzle number not listed in the injector thread.
The numbers on the nozzles are 9492 and I'm curious about the number of holes and their sizes.
The application they were from is a 300 horse 5.9 12 valve.
If anyone can help, I'd appreciate it!
Re: Injector nozzle size?
Postby oldestof11 » Thu Apr 07, 2011 4:02 pm
Know how many holes?
Also, VE 5.9L and P-pump 5.9L would have different holes, no? Higher injection pressures, etc. I know 2nd gen stock 160hp injectors have smaller holes.
Postby Mark Nixon » Thu Apr 07, 2011 4:20 pm
Can't see the number of holes and it's a P-3000 application.
I know the pressures are 240 bar.
Postby Smokem1 » Sat Apr 09, 2011 2:51 pm
Need the nozzle number. Or you could send them to me and I could tell you what they are.
Smokem1
Postby Mark Nixon » Sat Apr 09, 2011 4:00 pm
The numbers are 9492.
Same numbers are in the main posting.:lol:
Postby Smokem1 » Sun Apr 10, 2011 10:07 am
No, the DLLA-P or DSLA-P number from the nozzle.
Smokem1
Postby Mark Nixon » Sun Apr 10, 2011 6:57 pm
Well, dangit! :lol:
KDAL 59 P6 081 26
Postby KTA » Sun Apr 10, 2011 7:08 pm
Mark he is referring to a number you cant see without screwing the injector apart.
Postby Mark Nixon » Sun Apr 10, 2011 7:23 pm
I finally figured that out and was looking for wrenches when you replied, KTA. :lol:
The internal number is: DLLA145P 574
Postby Smokem1 » Sun Apr 10, 2011 8:25 pm
There you go. #0433171435 5x0.010" 145° mini sac nozzle with emission style pintle.
Smokem1
Postby Mark Nixon » Sun Apr 10, 2011 8:31 pm
So it's basically sized like a 215HP nozzle for a P-pumper.
Too bad one got bit by a valve. :shock:
Thank You for the information, Smokem!!!
Postby Smokem1 » Sun Apr 10, 2011 8:52 pm
I probably have 30-40 used nozzles of that type laying around, but they are typically more work than they are good for once they have miles on them.
Smokem1
