wannadiesel wrote: I suggest teeing into the supply line to the IP and running a hose from there to the return line, with a solenoid valve inline on the hose between the supply and return. When the system is in veggie mode, the stock lift pump would just sit there and recirculate the fuel in the tank.
Mine feeds straight into the dirty side banjo bolt on the filter head.Begle1 wrote:How do you have your Walbro plumbed in?
I'll have to draw a picture in MS-PaintCAD to see what I got to do...
Pumping veggie into your diesel contaminates the diesel you are using to flush the system to prevent gelling and deposits. You want to keep the diesel clean, if you have a good supply of WVO you might run around for 6-8 months on the same tank of diesel.Begle1 wrote:I don't know what happens if they mix in small amounts... I think they'd diffuse and it wouldn't be a problem. I don't think it'd coagulate, would it? I got an "F" in chemistry...
