he351 and ht3b?
he351 and ht3b?
Postby 92strokersmoker » Sun Apr 17, 2011 12:06 am
Is it doable? Also thinking a 6x.018
92 w250 NV4500, Denny T stage II, HE351, 5x.012, FPS maxed, 3200 spring, 1/4" timing bump, ALL guages, Carter fuel pump. And some more
92strokersmoker
Re: he351 and ht3b?
Postby AHineman » Sun Apr 17, 2011 2:12 am
Yes.
Re: he351 and ht3b?
Postby 92strokersmoker » Mon Apr 18, 2011 10:55 pm
I like that set up your runnin. What kind of numbers are you bringing in with that?
92strokersmoker
Re: he351 and ht3b?
Postby AHineman » Tue Apr 19, 2011 5:09 pm
Thanks. I don't know yet. Truck is down because of injection pump failure. I'm wanting to dyno it at Buckeye Blast in Hebron, Ohio on June 4 unless something bad happens. http://www.competitiondiesel.com/forums/showthread.php?t=104507 I didn't get my 100psi boost gauge or drive pressure gauge on before the VE died, but boost is 60+psi and egts max out at 1250* (empty, but not treating it very nice :lol: ). Here is a link to a he351/ht3b twin set that someone put on a 24valve. http://www.dieseltruckresource.com/dev/he351-ht3b-twin-build-t258338.html. I set mine up the way I did to keep from having to modify the firewall like I believe you would have to do setting them up 2nd gen style (for downpipe clearance). I also have decent access to my oil filter. Me, SNOOT, DLittle, BGilbert, CaptainChrysler, JAyers, BC847,and Swank all have pics of our setups online. I may have forgotten some as well. I wish KTA would post some pics of his setup on Old Yellow. 8)
Re: he351 and ht3b?
Postby dazedandconfused » Tue Apr 19, 2011 5:35 pm
KTA use to have tons of pics of Diesel-Central but they got deleted when that site disappeared.
Re: he351 and ht3b?
Postby AHineman » Tue Apr 19, 2011 5:52 pm
I remember seeing that site a long time ago, but when I started searching for it again later I found nothing. I'd say a lot of good info was lost when that site disappeared. Maybe he'll feel generous and post some pics on here. :D
Re: he351 and ht3b?
Postby dazedandconfused » Tue Apr 19, 2011 5:56 pm
There was a ton of good info on that site. It's a shame it's all gone.
Re: he351 and ht3b?
Postby 92strokersmoker » Tue Apr 19, 2011 6:35 pm
well ill be happy if i can tweak some stuff to get 1100+ ft/lbs with mine then i call it good for a while
92strokersmoker
Re: he351 and ht3b?
Postby AHineman » Tue Apr 19, 2011 6:38 pm
92strokersmoker wrote:well ill be happy if i can tweak some stuff to get 1100+ ft/lbs with mine then i call it good for a while
I'd hope so. :lol:
