My VGT setup.
My VGT setup.
Postby huntinguy » Wed Jun 22, 2011 7:41 pm
I posted this on CF but I know some of you arn't on there so I figured I'd let you see it too.
I think I have it dialed in pretty good right now. lights almost right away, makes 45psi. Mods are, ground fuel pin. pump almost maxed,(unknown injectors) procomp lift pump, timing to the head and 4" exaust.
With this turbo I hit 1700* at 85mph in 4th gear. before the turbo and the timing I could hit 2100* in 4th gear. :oops: A few more mod's are in order but I'm getting closer. :D
If you didn't know this is a he351vgt. I'm useing drive presure to open the turbo, a spring to close it and boost to balance it out. I have a filter and a needle valve on the drive presure line.
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Re: My VGT setup.
Postby Ram360man » Wed Jun 22, 2011 7:50 pm
Nice. I have pretty much the same setup but a 60mm H1C. I can hit 1800 with stock injectors. Before the turbo I could hit 2100 with a 1/8 inch timing bump.
1989 W250. Maxed fuel pump. 5x14. 63/68/14. PS Intercooler. 4200 gov spring. 188/220 cam. Built 727
1989 W250 60mm gds. 2.5 inch crossover. turned up pump. Stock 727.
Ram360man
Re: My VGT setup.
Postby AHineman » Wed Jun 22, 2011 9:09 pm
Ram360man wrote:Nice. I have pretty much the same setup but a 60mm H1C. I can hit 1800 with stock injectors. Before the turbo I could hit 2100 with a 1/8 inch timing bump.
I bet your pistons love you. :lol:
Re: My VGT setup.
Postby Marty Z » Wed Jun 22, 2011 9:55 pm
Looks Good but you need a bigger filter
1991 350 4X4 5 Speed he351vgt with brake 5.12 sdx injectors 60#springs 4" exhast 366 spring pump mods Holley fuel pump Gages 190000 miles
Marty Z
Re: My VGT setup.
Postby Ram360man » Thu Jun 23, 2011 2:04 pm
Doubt it. They looked fine when i pulled the head. Just need to hook up the intercooler sitting in my grille doing nothing.
Ram360man
Re: My VGT setup.
Postby Marty Z » Thu Jun 23, 2011 5:58 pm
Just living on borrowed time :bom:
Marty Z
Re: My VGT setup.
Postby huntinguy » Mon Jan 14, 2013 1:10 pm
Update!
This truck is now intercooled and cranked up a little more. It did 15.853 in the 1/4 mile this summer with 33's and a bad boost leak.
This fall it put down 346hp on 35's with a minor boost leak.
This dyno didn't have a brake and my rear brakes were out so the number is a little low.
Looking a little less ugly these days.
huntinguy
Re: My VGT setup.
Postby huntinguy » Mon Jan 14, 2013 1:15 pm
huntinguy
Re: My VGT setup.
Postby cmann250 » Mon Jan 14, 2013 1:32 pm
Minor subject change... Did you keep your A/C condensor with that intercooler? If so how?
Re: My VGT setup.
Postby dunes450r » Mon Jan 14, 2013 1:41 pm
cmann250 wrote:Minor subject change... Did you keep your A/C condensor with that intercooler? If so how?
similar topic: it appears you used a second gen intercooler? i have the same pickup, and a second gen intercooler. if ya wouldn't mind posting some pics of your install, and maybe what intercooler tubes you used?
thanks!!
dunes450r
Re: My VGT setup.
Postby huntinguy » Tue Jan 15, 2013 6:41 am
No more AC and my tubes are custom made.
huntinguy
