Water/ Meth & Boost Question
Postby Mike T. » Sat Aug 25, 2007 8:00 am
Lets say your capable of making 33psi boost on #2 and with W/M your up to 40psi +, what happens when wour wastegate is set @ 35psi, will it fall on it's face?
Thanks
93 w350 ext. cab,auto,354s,4"exh., smokey mt.,bhaf,htb2 62/65/12,CoolerTubz, ddp 55lpm inj.,Timed 1/8,Valet Switch,Piston LP,mild pump,3200 spring,ddp pin,Goerend TC,25k gvw trans cooler, deep pan,gauges,egt is pre.
Mike T.
Postby wannadiesel » Sat Aug 25, 2007 4:23 pm
Nope, it will keep right on pulling. 35 psi is about as high as is useful on a stock turbo.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Mike T. » Sat Aug 25, 2007 4:44 pm
Thanks Dave
Mike T.
