lp piston pump.
lp piston pump.
Postby meby » Fri Sep 09, 2011 8:55 am
I just ordered a lp piston lift pump and the related parts. Can't wait to see the difference between the old worn out stocker and the new one. :lol:
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: lp piston pump.
Postby PToombs » Sat Sep 10, 2011 5:50 pm
About 10 psi! ;)
Re: lp piston pump.
Postby meby » Mon Sep 12, 2011 3:44 pm
PToombs wrote:About 10 psi! ;)
LOL. I meant power wise. Even before the stocker went bad, I was sucking it dry. With a good lift pump it should crank out a couple more ponies. :D
-Case 530 CK
www.ebyfarmsllc.com
meby
Re: lp piston pump.
Postby PToombs » Mon Sep 12, 2011 5:18 pm
It should be noticeable. It may even smoke less. DP put one on one of his trucks and the truck ran better and smoked less. More fuel to the IP gave a better atomization must be.
Re: lp piston pump.
Postby CumminsPower59 » Mon Sep 12, 2011 6:14 pm
What does a stock lp put out? I have a mechanical Isspro gauge and I am getting about 4.5-5psi on mine...drops a bit at WOT, but not less than 2psi. Normal?
Re: lp piston pump.
Postby PToombs » Tue Sep 13, 2011 5:43 pm
Sounds about right. IIRC, specs are not below 3 psi at WOT, but 2 isn't bad. I've seen them with 2 or 3 at idle and nothing above idle. :shock:
Re: lp piston pump.
Postby meby » Thu Sep 15, 2011 8:33 am
PToombs wrote:It should be noticeable. It may even smoke less. DP put one on one of his trucks and the truck ran better and smoked less. More fuel to the IP gave a better atomization must be.
From your keyboard to my trucks ears. :lol: The rest of the parts are scheduled to show up today. I can't wait. :bounce:
-Case 530 CK
www.ebyfarmsllc.com
meby
