Broncman wrote:Those are my thoughts as well, but just not sure on sizing etc.
So bigger injectors could possibly atomize better? Which injectors should I start looking at? Again, this is not a horespower driven effort , but the most I can build reliably at a decent EGT. if it is only 250, then so be it.
Bigger radiator and intercooler are in the plans.
Tacoclaw wrote:Sounds like you got friends in high places!
Please share what he tells you with us if you don't mind, there's not a lot of actual engineering that goes into the mods around here. It's just mostly what's already been proven to work, but with no data to explain it.
crewcab59 wrote:I run an s300 62/65/14 and when i pull my 32ft 5er toy hauler it weighs in about 13000 lbs. i have 5x14 though but i tried taking them out and put in the stockers and it wouldn't boost at all and was worse for power and egt ???? even turning down the pump didn't work (way too gutlass) The main problem is it wont hold boost at traveling speed so the egt's creep right on up. quit fast it will easily go to 1400 deg. from a stop light, or up a windy hill so you can floor it, it will stay under 1100 with 30 lbs of boost but soon as you let off, the boost is about 7 to 10 psi. from there useless cause. I used the hy-9 for a bit and pulling it was perfect for that it never dropped below 20 psi, I blocked the waste gate and ran it up to 40 lbs of boost. but then at freeway speeds it couldn't handle it eather and would bury the gauge ( ya i heard i was lucky not to scatter the hy)so my next step is twinns. But for someone who doesn't have a turbo yet I would maybe go with a 62/12 or 64/12 or something that will hold boost at lower rpm's (without the trailer none of this is relevant) I hope my troubles help someone else. thanks, good thread
ahale2772 wrote:VE's like power down low, why not give them flow and low RPM volumetric efficiency so that they can make clean cool power.
if I was to build a tow motor I would focus on cam, cylinder head flow, and cooling
