ahale2772 wrote:dosnt make sense to not clip it... unless one was to somehow clock the throttle shaft and take up that difference
Ive got one sitting here and its longer, its logic that it would need to be the same length IMO
BC847 wrote:- If you don't shorten the 3800rpm spring, you'll have to re-index the throttle-lever so as to have full throttle available.
The_Head wrote:BC847 wrote:- If you don't shorten the 3800rpm spring, you'll have to re-index the throttle-lever so as to have full throttle available.
Is it a MUST to shorten the spring for an auto truck, so you keep the throttle lever in the right place, to avoid messing up the transmissions shifting?
BC847 wrote: . . .. without actually pulling on the gizmo (raising the fuel).
BC847 wrote:NOTE: That gizmo that the throttle tugs on with the spring, is also influenced by the fuel-screw and the governor mechanism.
Users browsing this forum: No registered users and 107 guests
