Also levi, lets leave the told you shouldve stayed with a ve comments to a minimum lol
Tacoclaw wrote:The AFC housing is rubbing the bottom of the end of the master, right on the outside corner bolt of it. It needs either an inch chopped off the end master, or that corner of the AFC choppped off to fit the way it was sitting when I was there. They're setting the mounts back the way mine are and bolting up the X member, then unbolting the master and fitting iit back on once the engine is down. He may just have it bty just doing that, but if not he's got the master off the 2ndgen to throw on it too.
The trans is supported with a jack, but I was eyeballing it while I was there and it could be a little low.
bgilbert wrote:So you have the tranny bolted to the engine and the engine/tranny combo are resting on the tranny crossmember?
Tacoclaw wrote:Justin, I don't have enough servicet to send out a text.
You can take the book, but there's only one pic of the mounts and it's not a great one.
PToombs wrote:Loosen the mounts, and jack the passenger side up a little bit. Sometimes this will let the drivers side drop in the slots and level itself. I've done it before with gassers, and we did it with pultilbrokes in the spring. His was a lot harder due to the vehicle history....
Tacoclaw wrote:It's rejecting the Pee pump!!
