HY35 flange contraption?
Postby Begle1 » Mon Sep 24, 2007 4:51 pm
How is one supposed to hook one's downpipe to that flange contraption? Do they all have that?
Postby PToombs » Mon Sep 24, 2007 5:00 pm
Geez, what's that off? I have one off a '01, and it has the bolt on exhaust housing. I took the funny one off and put my 16 on. Actually, I left the 16 on the truck, and swapped the rest on to it.
And to answer your question, yup!
Postby Begle1 » Mon Sep 24, 2007 5:17 pm
PToombs wrote:Geez, what's that off? I have one off a '01, and it has the bolt on exhaust housing. I took the funny one off and put my 16 on. Actually, I left the 16 on the truck, and swapped the rest on to it.
You put the compressor and wheels off of a HY into your H1C's 16cm housing?
How would I go about mating that thing to my truck's down pipe?
Postby PToombs » Mon Sep 24, 2007 5:22 pm
Aaahhhh! HY! I should read slower or pay more attention! :oops: I had an HX-35. I'm pretty sure you can buy 4" down pipes for a newer truck that have that flange. I don't have a clue on clearance though. With the funny looking cab and all! :lol:
Postby dpuckett » Mon Sep 24, 2007 6:52 pm
Get a flange off a 12v engine. It will bolt onto the turbine outlet of the HY. Or it should. Someone with absolute knowledge should verify this. You can always get a 2ndGen downpipe and cut the flange off it.
Daniel
Postby DTanklage » Mon Sep 24, 2007 10:52 pm
i have a 1st gen down pipe that will bolt right to that turbo
heck, i have the whole ex system! (3-3.5-4" step sys)
don
DTanklage
Postby Begle1 » Tue Sep 25, 2007 6:40 am
Where'd you get it from?
If I can just get a second gen downpipe, I'd be fine. As long as the flange and downpipe combination don't end up firmly implanted in my firewall.
Postby DTanklage » Tue Sep 25, 2007 6:59 am
i built it
why would it run into your firewall?
do you have a 1st gen?
DTanklage
Postby Begle1 » Tue Sep 25, 2007 7:20 am
I have an 1990 automatic.
I would guess that they put the flange on the turbo so that the downpipe could go straight down without having the 90 degree bend on top of the pipe.
The flange looks like it is made so that a straight downpipe goes straight down? Or would it angle back a little bit?
I just don't want to get a second gen downpipe and then realize that, when I bolt it onto the flange, it's trying to angle itself into the firewall.
Postby DTanklage » Tue Sep 25, 2007 8:12 am
look at the angle created between the flange that the dp bolts to and the ex housing itself
that would have to be 90° for the dp to go straight down
it isnt
2nd gen dp's do not fit on our trucks
DTanklage
Postby Falcon » Tue Sep 25, 2007 8:38 am
All you need is a adapter plate for the exaust housing to fit your stock v clamp pipe. I just sent one off to a guy in Oklahoma. They cost around $90.00 for a new one or you can find one used for around $30.00. You will need a gasket to fit or use high temp goop. It will push your exaust back about 3/4 inch back just loosen your exaust clamps at the tranny and it will push back.
Greg
Greg
Graham, Washington
"FIRST REAL TRUCK ENGINE...
LAST REAL TRUCK!!!
93 ex cab 4x4, Hybred 35/40,4" exaust all the way,pump turned alittle,DDP Stage III's, 366 spring,DDP fuel pin,AFE first gen air intake,pyro and boost gauges
Falcon
Postby Begle1 » Tue Sep 25, 2007 8:41 am
Falcon wrote:All you need is a adapter plate for the exaust housing to fit your stock v clamp pipe.
Greg
What does this adapter plate look like and where do I get one?
Postby Falcon » Tue Sep 25, 2007 8:47 am
Greg
You see where the down pipe bolts on to the back of the exaust housing I think 5 bolts? take that off and the v clamp adapter bolts on there then all you do is connect the stock down pipe to it.
Greg
Graham, Washington
LAST REAL TRUCK!!!
Falcon
Postby Begle1 » Tue Sep 25, 2007 9:00 am
Excellent. Thank you.
Know where I can get an adapter plate? Rip Rook?
Postby Falcon » Tue Sep 25, 2007 9:02 am
Greg
Graham, Washington
LAST REAL TRUCK!!!
Falcon
