Air Dog Install Questions
Postby cummins12club » Sun Jan 06, 2013 6:28 pm
Installed an air dog 150 tonight no issues except my idle went up to just over 1000 is that normal?
cummins12club
Re: Air Dog Install Questions
Postby AHineman » Sun Jan 06, 2013 6:43 pm
The big line and fittings interfered with my throttle linkage and I had to do a little dremel work to let it hit the idle stop, get full throttle, etc. Is that your issue?
Seems like everyone's linkage is a little different, but you can see where I had to grind a little spot. It's close to the threads on my fitting.
Postby cummins12club » Mon Jan 07, 2013 6:34 am
Ill have to check that out today that may be my issue I was thinking the new found fuel pressure bumped the idle
cummins12club
Postby skilletky » Mon Jan 07, 2013 10:38 am
AHineman wrote:The big line and fittings interfered with my throttle linkage and I had to do a little dremel work to let it hit the idle stop, get full throttle, etc. Is that your issue?
you got part #'s for the fittings you used?
logan, where did you end up wiring the power wire too? sorry, i fogot to text ya back that day. did you get the regular air dog or the airdog II?
skilletky
Postby AHineman » Mon Jan 07, 2013 11:51 am
skilletky wrote:you got part #'s for the fittings you used?
The fittings in the photo are:
http://www.vulcanperformance.com/Metric-Adapter-08-JIC-X-12mm-p/m1208.htm
http://www.vulcanperformance.com/Pushlock-Swivel-08-JIC-X-1-2-PL-p/po188.htm
http://www.vulcanperformance.com/08-Male-JIC-x-Female-08-JIC-Swivel-p/650088.htm
Mine came with the quick connect fittings, but they were in the way of getting full throttle on the pump. I went back to pushlock JIC stuff for the whole setup. 8)
Postby cummins12club » Mon Jan 07, 2013 2:09 pm
Well u know that mini fuse plug in deal well I went to the store and bought the same thing in a bigger fuse style and put it in where the radio fuse went and put the radio fuse in the new piece I bought works great
cummins12club
Postby cummins12club » Mon Jan 07, 2013 2:10 pm
Yup that was my issue the throttle linkage was hitti g the feed line quick disconnect
cummins12club
