Large injector lines
Postby ford69557ci » Mon Oct 29, 2007 9:01 am
I know the p pump guys run them and now the vp44 guys are runnin them. With the 14mm pump and some big injectors what would larger lines do? If not better performance would it atleast give that killer idle that the big line p pupm and vp guys have?
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 9:47 am
from what i have heard you will lose bottom end with that 'killer idle'
DTanklage
Postby ford69557ci » Mon Oct 29, 2007 10:32 am
not a prob all this truck does is race and pull and in 2wd all i can do is destroy tires so maybe losin some bottom end power might be useful
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 11:40 am
good point...
then again, when it does clean up and come on it is gonna hit harder
(destroy tires even more...lol)
DTanklage
Postby ford69557ci » Mon Oct 29, 2007 5:13 pm
well as long as its in 4x4 eatin tires theat way they all wear the same :lol:
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 7:26 pm
dont do like josh did...
he put that unit on his truck
his tires were over 4 yrs old
and the damn nitrous blew the tires off the rims!
(16.5's are not the way to go for what you guys are doing)
DTanklage
Postby ford69557ci » Tue Oct 30, 2007 9:57 am
good thing a have 16's i used to rool tire off the rim and my mud truck and it had 16'5 wheels somethin about not havin a saftey bead??
ford69557ci
Postby DTanklage » Tue Oct 30, 2007 11:17 am
exactly
DTanklage
Postby cummins king » Tue Oct 30, 2007 9:14 pm
so your sain that if you put bigger injector lines you will lose bottom end power but at the top end you gain more, if so what size lines would you have to put on and how many psi is in those line would you think
you probaly would have to run a 14mm ve with dual feed 8) what a cool set up that would be (some day)
93 4X4 auto
cummins king
Postby ford69557ci » Wed Oct 31, 2007 10:52 am
im not sure i was thinkin on some .093 lines thats what the vp44 guys are runnin on thier rotary pumps so thats where i am goin to start.
ford69557ci
Postby bgilbert » Thu Nov 01, 2007 7:20 pm
Since Don is good at math, what is 1.8mm in inches? That is what size injection lines you have ford guy if they are stock non-intercooled lines. IC'd lines are 1.6mm id.
Bill Gilbert
bgilbert
Postby DTanklage » Fri Nov 02, 2007 12:30 am
070 and 063 bill
but you cant compare flow looking at the diameter numbers
to compare flow you have to figure out the cross sectional area
(half the diameter squared times pie)
093 is a big increase, almost twice as big
.00385 and .00312
vs .00679
DTanklage
Postby ford69557ci » Tue Nov 06, 2007 11:44 am
well i am havin some .093 and some .100 made up so i guess one of these days i will see what happens
ford69557ci
Postby hassy21 » Tue Nov 06, 2007 12:14 pm
Does anybody sell the bigger injector lines or where would you have them made?
hassy21
Postby DTanklage » Tue Nov 06, 2007 2:04 pm
woodruff diesel
DTanklage
