Turbo upgrade/turbo whistle
Postby cutterman » Mon Feb 25, 2013 8:56 pm
The stock turbo on my donor motor seems to have a tight spot so I am looking to upgrade and am thinking of using a take off he351cw, what will I need to do to make it fit my 1990 non I/c motor and would it have a 4" exhaust flange? Also I love to have good "turbo whistle" will this one give me that or should I look at something else.
cutterman
Re: Turbo upgrade/turbo whistle
Postby BILTIT » Mon Feb 25, 2013 9:59 pm
Do a quick search, you should find lots of info for this turbo. I know i have explained many times what i used to install mine, and yes it will give you some whistle. Use an aftermarket cold air intake to get more whistle.
Derek B.
BILTIT
Postby RCCUMMINS89 » Mon Feb 25, 2013 10:04 pm
They are decently loud. They require a 4.3ish" flange, you can buy an adapter that either bolts onto a 4" exhaust pipe or weld onto a 4" exhaust pipe.
You'll have to manufacture some sort of crossover pipe or at least cross over connection to the turbo, because they have a 90 degree forward facing outlet.
You'll have to upgrade your intake tube from 3 to 4 inches as well.
Other than that, the rest isn't really modifying.
Postby BILTIT » Tue Feb 26, 2013 8:36 am
RCC- does the non-IC have a different intake tube VS the IC? I ask because i am using my stock intake tube but i assume the non-IC's had smaller.
Derek B.
BILTIT
Postby RCCUMMINS89 » Tue Feb 26, 2013 8:49 am
You mean the intake tube from the air filter to the turbo? Ya the non i/c is 3" and i/c is 4"
Postby cutterman » Tue Feb 26, 2013 12:12 pm
BILTIT, how do I do a search, I guess I haven't found the search button yet?
cutterman
Postby cmann250 » Tue Feb 26, 2013 12:17 pm
Postby BILTIT » Tue Feb 26, 2013 1:01 pm
Thanks cmann.
The search bar is at the top right of this current page, just scroll up and go to advanced search.
Derek B.
BILTIT
