twins
twins
Postby cummins king » Sat Nov 03, 2007 2:26 pm
okay got talking to some guys at the dyno to day and they said that a resonably good set of twins for 500 to 700 hp would be and hx35 on top and and htb3 on the bottom, what you guys think
93 4X4 auto
cummins king
Postby ford69557ci » Sat Nov 03, 2007 4:57 pm
maybe and hx40 and and htb3. the 35 just doesnt move enough air for that kinda power. a really good combo for those power levels is a s300 and s400 combo.
ford69557ci
Postby cummins king » Sat Nov 03, 2007 6:38 pm
yes s300 and s400 would be nice but i can get hx40 and btb3 alot cheaper
93 4X4 auto
cummins king
Postby ford69557ci » Sun Nov 04, 2007 3:25 pm
as long as you get the right ex housings on the 40 and ht3b they will work great just stay away from the 35. i think the piers street twin setup is a 40 and a ht3b and they r good for around 600hp
ford69557ci
Postby cummins king » Sun Nov 04, 2007 6:35 pm
ford69557ci how do you like you cat turbo set up, why didyou chose that one and how much hp do youthink its good for
93 4X4 auto
cummins king
Postby ford69557ci » Mon Nov 05, 2007 11:24 am
i love it for now but when i do the 14mm and some larger injectors i am goin twins. i went with it because its an s300 64-71 and i can buy them all day long at my local heavy engine core place for 300 350 bucks. it keeps the egt cool enough that i dont have to use the water unless i am towing cuz i am still non ic.
ford69557ci
Postby Paccool » Mon Nov 05, 2007 2:36 pm
I'm running a PDR modified HX-35 on top with a HT3B on the bottom. The 35 has a wastegated 12 housing. Wastegate is set at 28 psi. With a big set of sticks, I buried my 60 psi boost gauge. With a set of DDP stage three injectors I was running about 56 psi. The 3B turns on at about 18-20 psi boost.
Right now I have my old set of 185 injectors installed and have turned things down for trailer towing. Still have about 46 psi of boost even with these small injectors.
Stan
93 D250, PDR cam,stage 2 head w/o-rings,twin turbos HX35 on top HT3B on the bottom,modified IP,piston lift pump,DDP stage 3 injectors,gauges,ATS ported manifold,4" exhaust,5" inlet system,oversized intercooler, rear sway bar, fresh paint
Paccool
Postby cummins king » Mon Nov 05, 2007 3:56 pm
ford69557ci
how much boost can you make
93 4X4 auto
cummins king
Postby cummins king » Mon Nov 05, 2007 3:57 pm
and does it fit right up to the cummins manifold
93 4X4 auto
cummins king
Postby ford69557ci » Mon Nov 05, 2007 4:53 pm
bolt right to the factory manifold and i have the gate set at 50 i am seen just how much that stock head gasket will take :mad:
ford69557ci
Postby cummins king » Mon Nov 05, 2007 5:31 pm
hey what did u have to tell the cat guys to get the right one, ie. motor it came off of, it would be an awsome to turbo, and did you have to retorque the head to get up to 50 pounds
93 4X4 auto
cummins king
Postby ford69557ci » Mon Nov 05, 2007 7:38 pm
its is off of a c-7 cat or the older version of the engine is a 3126 its the same turbo it just has a smaller outlet on the compressor side
ford69557ci
Postby cummins king » Mon Nov 05, 2007 7:53 pm
on the new c7 Rv's its rated for 350hp u think it would be the same turbo, and they say they cant help me unless i get a seriel number
93 4X4 auto
cummins king
Postby ford69557ci » Mon Nov 05, 2007 8:57 pm
mine is from a 300 hp f550 but the 350hp rv turbo is the same somewhere in late 04 the went to a variable geometry turbo and that wont work unless you are one awesome computer and wiring person
I got my turbo at the local heavy duty engine core place. The cat guys are like the cummins parts guy no number no part i think if your goin to work at a place like that maybe you should first know what a c-7 or a 3126 cat is lol
ford69557ci
Postby cummins king » Tue Nov 06, 2007 5:55 am
no arguing there
93 4X4 auto
cummins king
