Just food for thought about runaway
Postby RCCUMMINS89 » Thu Jun 06, 2013 10:36 am
You can't always hit runaway in the driveway.
Keep in mind that the slide collar can't move much past 1/4 throttle with a working afc.
So you can't technically get full slide collar movement (which controlls when it runsaway) unles you are under full boost.
Obviously I'm bringing this up because even though I know my pump pretty well and tested for if it was going to do it in the driveway........the second I hit 45 psi on the boost gauge while driving she took off like a bat out of hell.
Luckily I was able to stop it while slamming on the brakes and I was still doing under a 100mph :roll:
Re: Just food for thought about runaway
Postby dantheman300z » Mon Dec 09, 2013 3:42 pm
I was wondering about runaway the other day, what really causes it and is it more likely on a H1C and a turned up pump compared to a better turbo?
dantheman300z
Postby DMan1198 » Mon Dec 09, 2013 6:37 pm
The pump is what'll cause it to runaway. If your turbo is causing it that's a very different problem. When you turn the fuel screw it lengthens the injection event. Go too far and the rack sticks at WOT giving you a runaway condition.
Postby skilletky » Mon Dec 09, 2013 7:01 pm
ive had it happen to me twice at the end of the track. i always keep a socket and ratched along with my 17mm wrench in the glove box
skilletky
Postby dantheman300z » Thu Dec 12, 2013 10:16 am
Oh i see, but there are upgrades that vary the chance of runaway right?
dantheman300z
Postby DodgeFreak » Thu Dec 12, 2013 11:32 am
could you have just shut it off or was it true runaway??? I've had dads "runaway" but it was a true runaway I was able to shut the key off and stop the fueling. Something was stuck inside the pump. I haven't had the pleasure of an extreme runaway and nor do I want to.. It kinda scares the crap out of me lol.
