a turbo question
a turbo question
Postby truckwrench1 » Sat Jan 18, 2014 1:45 pm
ok got a QUESTION what is the largest single that will spool the best with a hamilton/colt cam, tuned pump 5x12/5x14 injectors with the m&h timing spacer with close to stock timing. looking for the 450 hp area with decent mannors can live with haze and some smoke.
truckwrench1
Re: a turbo question
Postby RCCUMMINS89 » Sat Jan 18, 2014 1:49 pm
Trans? Gearing? Tire size?
450hp is going to take a lot of timing and larger than 5x12-5x14 injectors unless some nozzle/pintle work is done.
Postby truckwrench1 » Sat Jan 18, 2014 2:49 pm
standard, gearing in th 3.50 range, 16.5 standard size tires dually, nozzle pintle work is ok with me. looking to lay some ground work for a fresh build, may even consider marine pistons.
truckwrench1
Postby RCCUMMINS89 » Sat Jan 18, 2014 2:52 pm
Marine pistons accompanied with marine angle injectors will make better/more efficient power.
62-63 compressor wheel with a 68-71 turbine wheel will suffice. fyi...I'm running a 62/68 for the 450-500hp goal.
If I had to throw out a turbo/inj recommendation with the little information so far....63/68/.8 with 70-80lpm marine SAC injectors. 64/71/.8 would work as well, but it's not going to have good street manners.
Postby truckwrench1 » Sat Jan 18, 2014 2:58 pm
well then i guess maybe i need to ask the question differently, as far as spooling a large turbo what gains are seen with the cam swap ? and thanks for the recomendations so far rccummins
truckwrench1
Postby RCCUMMINS89 » Sat Jan 18, 2014 3:08 pm
There are major gains in spool ability when putting in a cam. But there is no answer to it, as the given set up will change the benefit of the cam swap.
Postby truckwrench1 » Sat Jan 18, 2014 3:23 pm
thanks man guess i will have to do my homework
truckwrench1
Users browsing this forum: No registered users and 57 guests
