Twins h1c and hx55?
Twins h1c and hx55?
Postby 89cumburb » Fri Mar 28, 2014 7:19 am
I'm looking to do twins ad right now I have an h1c with a 60mm compressor and a hx55 I have 5x14 injectors and a 3800 gov spring 60lb valve springs and some timing work anyone know how this set up will work out and anyone have anything simular?
89cumburb
Re: Twins h1c and hx55?
Postby Sutter1stgen » Fri Mar 28, 2014 4:56 pm
Stackx2 on the other forums built a set from a 67mm inducer hx55. With pods and a 5 speed he put down 337/72?
I later ran the setup with my super40/35 hybrid. I had ddp3s 5x12s and I put down 330/660 through a non lockup auto.
Both of our trucks could not exceed 1200 towing(he gross'd 24k from ca to tx). They were a fun ve matched set, and if I did a mild ve truck again they'd get the nod.
Eric
Sutter1stgen
Postby 89dudney » Mon Mar 31, 2014 7:46 pm
So what would it take to run twins with a h1c and hx55? I was also thinkin about doing this, but with 5x16s????
I like my truck more than I like 99.9 percent of people...
89dudney
