HT60
HT60
Postby GPSMatt » Fri Nov 30, 2007 4:08 am
any input? cant find much info on the net about them. I picked one up locally for a good deal
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby KTA » Fri Nov 30, 2007 6:59 am
They are the new improved version of the HT3B.
Postby cummins king » Fri Nov 30, 2007 4:15 pm
is the hx60 still better and do you think you could spool a hx82 witth and hx40 witha a set of 6x20 injctors what would be better then and hx 60 but smaller then an hx82
sorry about all the questions
93 4X4 auto
cummins king
Postby GPSMatt » Fri Nov 30, 2007 4:43 pm
I have been looking around some more on the net and found the Ht's are reverse rotation?
and an hx82 is freeking huge my ht 60 is real big
[/img]http://i210.photobucket.com/albums/bb201/toy4xchris/2003_1220003.jpg[img]
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby cummins king » Fri Nov 30, 2007 4:51 pm
ya but is your th60 bigger then a hx60
93 4X4 auto
cummins king
Postby ford69557ci » Fri Nov 30, 2007 4:52 pm
hx 80 is 1100hp p pumps stuff i just got my s480 in and i am note sure if it is going to spool?
ford69557ci
Postby cummins king » Fri Nov 30, 2007 4:54 pm
hx 80 i can spool when i need the power, the hx 40 is street, remember here in canada if you go 50km over the crush your truck
93 4X4 auto
cummins king
Postby ford69557ci » Fri Nov 30, 2007 5:03 pm
i forgot the specs on an hx82 but i think it is close to 100mm and that would be great for a 5500 rpm pull truck movin 700 cc or better
ford69557ci
Postby cummins king » Fri Nov 30, 2007 6:18 pm
is there any ay to tell how much air a turbo can move or boost it can biuld, a calcuation
93 4X4 auto
cummins king
Postby Underpsi » Fri Nov 30, 2007 6:19 pm
When he said 700cc im pretty sure he was refering to the amount of fuel
1989 D250 5spd w/SB3250DD, .020 over head gasket, O-rings, Extensive port/polish, ARP head studs, 62/71/14, 6x.018 sticks. First Dyno stock turbo and pods: 343/879
2nd with 62 & big sticks: 393/813
Underpsi
Postby ford69557ci » Fri Nov 30, 2007 6:32 pm
yes 700 cc is the amount of fuel and i think over on comp diesel there is a really good post about the cfm flow rates of alot of different turbos
ford69557ci
Postby KTA » Sat Dec 01, 2007 6:20 am
The hx60 replaced the HT60 so it is the upgraded and improved version of the same thing size wise anyways.
Postby cummins king » Sat Dec 01, 2007 7:25 am
whats the next turbo up from a hx 60
93 4X4 auto
cummins king
Postby 92 D/UNIT » Sat Dec 01, 2007 8:23 am
cummins king wrote:whats the next turbo up from a hx 60
an HT80, BIG!
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby ford69557ci » Sat Dec 01, 2007 12:58 pm
i was tryin to find that thing on comp diesel but i remeber the hx82 moved like 1450 cfm or somethin like that
ford69557ci
