Pop pressure
Pop pressure
Postby Mike T. » Wed Dec 26, 2007 4:30 pm
Has anyone increased the pop pressure on there injectors? Just wondering if there would be better atomization with a bump in pressure. I'm sure there's also down side.
Thanks
Mike
93 w350 ext. cab,auto,354s,4"exh., smokey mt.,bhaf,htb2 62/65/12,CoolerTubz, ddp 55lpm inj.,Timed 1/8,Valet Switch,Piston LP,mild pump,3200 spring,ddp pin,Goerend TC,25k gvw trans cooler, deep pan,gauges,egt is pre.
Mike T.
Postby cummins king » Wed Dec 26, 2007 4:45 pm
increasig the pop pressures would hert the ic pump thats y you cant us second gen injectors unless you lower the pop pressure
93 4X4 auto
cummins king
Postby Mike T. » Wed Dec 26, 2007 4:52 pm
Thanks c. king
I was just thinking if a slight amount would be a benefit.
Mike
Mike T.
Postby cummins king » Wed Dec 26, 2007 6:03 pm
i really dont know about a slight amount
93 4X4 auto
cummins king
Postby dpuckett » Thu Dec 27, 2007 5:58 pm
My injectors are set to 3800psi. Only difference I have noticed is a reduction in MPGs, if that is the cause. I think stock pressure atomizes pretty well. If you want a finer spray, try EDM or extrude honing. You really dont need to put any more stress on the VE than is absolutely necessary. If someone will give me the directions for how to build a home pop tester, I am considering lowering mine to 34-3500 or so.
ANother reason (and the main reason) you cant use 2nd Gen injectors in a 1stGen engine is that the threads on the bodies are different sizes, and the lines wont be a direct fit.
Daniel
Postby Mike T. » Fri Dec 28, 2007 3:42 pm
Thanks Daniel,
Just thought it would atomize the fuel better and maybe clean things up a bit. But I guess that's not the case.
Mike
Mike T.
Postby Begle1 » Sat Dec 29, 2007 7:59 am
So would there be increased RPM capability if you lower the pop pressure?
Postby wannadiesel » Sat Dec 29, 2007 10:04 am
No.
Best dyno: 408/844
wannadiesel
diesel guru
