Im stacked!!! Pics/Vids inside
Postby rbrettctd » Sun Jan 06, 2008 3:02 pm
A full days work and some help from my buddies. . . . . and my 5" blackies are on!!! Sounds great. Loud but with all the windows shut its actually a little quieter than before. The smoke is pretty close to even. A couple of videos at the bottom too.
Randy
rbrettctd
Postby PToombs » Sun Jan 06, 2008 3:27 pm
Eeeewwww! Straight cuts! :shock:
;) :lol: :lol:
Really, they look good! Sound good too! I think they should have been about 2-3 inches longer, so they are just above the rack, but that's me! ;)
I see in the video they smoke uneven just a little, not as bad as mine though.
Good job! :thumright:
Postby rbrettctd » Sun Jan 06, 2008 4:15 pm
Thanks. I initially liked mitres better, but in Stephenville theres about a dozen of em sporting 5" mitres....I had to be different. A little taller would have been nice so you could see them from the front, but I ordered 36s and kept them that height. Add the 6" square tubing and 2" angle for mounts, and it came to 44, the same as the rack. I like it though, and the elbow underneath lined up perfect!!! Didnt have to cut flex, elbow, or stacks to make it all work.
Randy
rbrettctd
Postby CumminsPride » Sun Jan 06, 2008 6:03 pm
Nice! I love the black!
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby 92 D/UNIT » Sun Jan 06, 2008 6:24 pm
looks great! i loved the sound when i had mine on. word of caution, build some kind of cover or divider ive had stuff blow onto the stack box and melt. it gets pretty hot.
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby PToombs » Sun Jan 06, 2008 6:56 pm
I agree, the black sets it off! 8)
I hope you put drain holes in it someplace. I sleeved mine. Welded a 8" long piece of 4 inch pipe
to the 4" square tube, then welded a 5" coupler outside of that. Put the stacks in the coupler, and have a 1/2 inch gap at the front and back for drainage. ;-)
Postby burnt_servo » Sun Jan 06, 2008 11:31 pm
i wonder if some sort of heat exchanger could be built into the stack box to heat used veg oil .....
wheels are turning on this one :D
burnt_servo
Postby rbrettctd » Mon Jan 07, 2008 6:16 am
Thanks guys. Im just gonna drill some hole in each corner of the square and one in the middle, then one in the elbow for anything that gets that low. Were in the middle of a drought right now though so not a concern.
Im gonna build a d-plate cover of some sort for them.
Randy
rbrettctd
Postby DTanklage » Fri Jan 11, 2008 6:32 am
looks great randy
sounds great too
i know what would make that truck look even better tho...
my winch/bumper combo!!!
(i still got it if you are interested)
josh finally removed his stack and plumbed it out the back to save his ears
lol
how are your ears doing?
DTanklage
Postby cummins king » Fri Jan 11, 2008 7:33 am
how much you want for the combo
thanks
93 4X4 auto
cummins king
Postby rbrettctd » Sat Jan 12, 2008 8:54 am
Thanks but I actually have a nice bumper on there. Just not in the pics cause Im intercooling it right now. Heres my truck back when it was assembled.
Randy
rbrettctd
Postby DTanklage » Sat Jan 12, 2008 12:07 pm
that is nice
have fun w it
my combo belongs on a 4x4 anyways
DTanklage
Postby rbrettctd » Sat Jan 12, 2008 5:31 pm
That bumper looks sharp too. Thanks. Im hoping to get the cooler bolted up tomorrow so I can put the front end back together. Can everyone keep an eye out for an hx40 for me by the way? No more than I use it right now, I dont want to drop the 1200 for a PS.
Randy
rbrettctd
Postby cummins king » Sat Jan 12, 2008 9:38 pm
check ebay out theres a guy selling new ones cheap, search "holset"
93 4X4 auto
cummins king
Postby rbrettctd » Sun Jan 13, 2008 10:16 am
ARe housings easy to find aftermarket? I found some, but they have 14cm nonwastegate and 16-18 wastegate. I want a 14, but with my head like it is, I need to keep it below 40.
Randy
rbrettctd
