DTanklage wrote:
(gonna use this for towing coast to coast so no meth)
DTanklage wrote:first of all, that is the twin intake thing i was talking about (maybe in a diff thread?) that i fregin love
that thing has to help correct the terrible dist the cummins is notorious for
no?
I can't help but think it does. Apparently, based on conversations about it at DTR, I'm able to flow a lot more W/M without bog than many with the relatively same engine set-up.
second, aren't you worried about the water having to go uphill a little? wouldn't it be safer/better to move it 3" closer to the motor so it is in the horizontal part of your twin horn? i would think so but if you are not activating it until 25 psi i guess its not a prob. as long as it shuts off as soon as boost decreases to 25 psi.
In a perfect world, all the mist afforded by the nozzles is 100% entrained in the rather high speed CA flow (maybe not at low/no boost). Based on what I've seen the kit mfrs use, one can fab a right-angle nozzle that mounts centered in the CA duct that in theory offers the best in fog entrainment. The thing is, all that goes to crap with the first turn (fog impingement). The super topdawgs with bottomless pockets squirt directly into the back of the intake valve . . . . most likely with interstage fogging (we're talking GPM).
But no, it doesn't run down hill.
third, what setting brings the water in at 25 psi??? mine is 7# starting point on the low setting (100% @ 15 psi, which is what i will prolly be using the way this pig love water), 11# on med (100% @ 20 psi), or 11# starting and 25 100% on high. those are the numbers snow quoted me when the unit is in egt/boost mode. are you running boost only mode???
boost only would be fine for racing around but that is not what i am looking for. i need this thing to keep egts in check rolling at 33k# and hopefully get a mile or two per gallon more efficient
My controller (CoolerMist VariCool) can be considered stage II (Boost based exclusively). It offers three knobs to toy with. One controls the start pumping set-point (0 ~ 35psig boost). The second knob controls the full-on set-point (0 ~ 35psig boost).
Because the pump sorts sucks at 10 or 20% pumping capacity, combined with the thought the nozzles are gonna drool at low pressure, the controller's minimum on pump capacity is nailed to 30%. You can move those set-point anywhere you like on the boost scale. You can even have the knobs set so the figures actually overlap. as such, the controller will act as a simple Hobbs pressure switch. Again, anywhere you like.
The third knob allows one to custom tune the ramp between the start point, and full on point be it concave, or convex in profile (It can be further shaped by linking to you laptop. As such, you can also reap all the real-time data about the W/M mess).
only prob i think i am gonna see with controller in egt/boost mode is that on any of the 3 settings, l,m,or h, the water starts coming in at 700°
shoot, my truck is almost always above that empty!
what turbo are you running?
PDR HX35 Hybrid with a 14 WG'ed housing
do you tow?
Nope. Grocery-getter / Weekend warrior
i am running 62/65-13 (that is the 13 cm htt ex housing that i have heard runs hot but have nothing to compare to YET)
don
