4" IC piping
4" IC piping
Postby ford69557ci » Mon Feb 04, 2008 5:38 pm
I have noticed that alot of the big power power stroke guys are runnin 4" ic pipes. I know the cummins is quite a bit smaller but with twins and a massive amount of fuel that alot of poeple want to run wouldnt 4" pipes improve flow? I know it would slow down spool up but I would think there would be an egt reduction alot more flow and with an IC with 4" in/out and that large of a core there would have to be a benifit. I run 4" on my s 10 and so do most other 10.5 tire or faster turbo and procharged cars. Any ideas???
ford69557ci
Postby seeker1056 » Mon Feb 04, 2008 8:00 pm
air is a fluid
fluid is easier to push through bigger pipe at less pressure loss
I did a thread a while back on what psi it takes to push the minimum cfm required ( just shy of 1350 cfm) to make 700 hp through a 3" pipe and how much less it would take in psi though a larger pipe.
If memory serves it takes about 70-80 psi to make enough airflow to support 700 hp through our current 3" piping which in many cases is actually 2 3/4" leavin the turo, and enterin the stock gen1 intercooler.
Did you know even the 2007 has one intercooler outlet necked down to 2 3/4, even though all other boots and elbows are 3", to cut boost and pressure?
Dont confuse compression between the turbos and gettin air into the system with pushin the air once it leaves the turbos.
However I am not so sure that 3" between the turbos is good either but dont have the resources to test it.
The ideal setup may be three inch between the turbos, with a venturi leavin the last turbo into the 4" intercooler pipe to speed up the airflow and cool it at the same time via the pressure'flow changes and another venturi goin into the manifold for the same reasons.
It works on the same principal as air conditoning does to get pressure and cooling.
we will see wha t happens in the spring once i get my turbos sorted out and get a chance to play with piping and stuuff i have in mind
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby cummins king » Mon Feb 04, 2008 8:10 pm
well KTA said with a 4inch hot pipe it would beifit me greatly if i did a 3inch turbo to turbo tube, but i only have a 3inch turbo to intake tube, im not to sure what benifet this has but it has smthing to do with what your talking about
93 4X4 auto
cummins king
Postby KTA » Mon Feb 04, 2008 8:26 pm
The main problem with yours is you go up a bunch in size from your manifold turbo outlet, then have to size it back down to feed your atmosphere turbo. That makes turbulence, more lag, and makes you lose more heat you could have had to drive your atmo. charger.
Postby cummins king » Mon Feb 04, 2008 8:27 pm
so would it be better to go to a 3inch down pipe and a 3 ich turbo to turbo toube
93 4X4 auto
cummins king
Postby KTA » Mon Feb 04, 2008 8:34 pm
The pipe off your atmosphere exhaust can be whatever size you want, bigger is better. For your interstage piping I suggest keeping it no bigger than what the biggest dimension is between stages for optimum performance. For example say the inlet to your atmo exhaust is 3" stay 3 ", same goes for intake side piping.
Postby ford69557ci » Mon Feb 04, 2008 9:10 pm
my s 485 has a 5" inlet and almost 4" outlet on the compressor. i planned on runnin 4" into a 4" air/water then some more 4" to the s300 66-71 then from the s300 4" to a 4" in /out air/air left over from my s10 then from that 4" to a trick dual intake setup to match my zz fab intake??? at least i should have plenty of air?? what do ya think?
ford69557ci
Postby cummins king » Tue Feb 05, 2008 6:52 am
k then when i get my turbo to turbo tube made its going to be 3 inch and my crossove tube is going to be 3 inch
93 4X4 auto
cummins king
Postby seeker1056 » Tue Feb 05, 2008 9:15 am
somewhere on here is a pic of my setup with the water/air etc - you can get a good idea of piping etc from that as my turbos are mounted relatively high cuz the motor is in a Ford
However it does give you a feel for what the others are talking about in terms of piping
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby ford69557ci » Tue Feb 05, 2008 1:00 pm
seeker did you have your truck on ebay a while back? i am not mountin the big turbo down low it is goin to be over on the fender well so i can run my hood stack at the pulls and shows and if i put it over on the fender well it will make my piping shorter and be alot easier to work on.
ford69557ci
Postby seeker1056 » Tue Feb 05, 2008 1:24 pm
my big turbo is mounted above the motor
Yes my kid needed money for university and the truck "was" for sale last fall on Ebay.
Now its not for sale - gonna get somewhat serious about things here shortly
I think a VE can put the run on the p-pump promods here if i get to it, more because of the truck setup than the motor but who cares so long as i place top five or three or....;o).
Mr Ford - you consider buildin me a pump if you get yours workin? If so pm me
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
pix?
Postby seeker1056 » Tue Feb 05, 2008 1:31 pm
how do u post a pic here
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby ford69557ci » Tue Feb 05, 2008 1:41 pm
no clue how to post a pic. i will be happy to build anyone a pump as soon as it prove to make some power and stay together i dont wanna build somebody somethin right now cuz all i have is good flow numbers and no power proof or durabilty proof on the truck
ford69557ci
Postby PToombs » Tue Feb 05, 2008 3:00 pm
Can't post a pic. You have to host it thru Photobucket or 1 of those.
Postby cummins king » Tue Feb 05, 2008 6:08 pm
its acualy very easy to biuld up a pump, maby if you come to dyno day seeker then i will show you
93 4X4 auto
cummins king
