Twin Turbos
Twin Turbos
Postby opofus » Mon May 12, 2008 8:34 pm
I am not sure if this has been discussed, but I will ask the question anyway...
What is a good combo of turbos for a twin system. I have read the HX-35, is a good turbo.
I also have access to a turbo from a 2007 24v. It looks like it will bolt up direct, but it has an electronic wastegate. Any comments?
opofus
Postby cummins king » Tue May 13, 2008 4:13 am
a HTB3 is the common choice with the hx35
93 4X4 auto
cummins king
Postby MikeThomas » Tue May 13, 2008 8:40 am
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby CumminsPride » Tue May 13, 2008 10:58 am
I like the HT3B. Works quite well.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Which one first?
Postby opofus » Tue May 13, 2008 11:19 am
I work on a budget, so which would be better to get first, the HX 35 and put it on and run it until I get the second one, or the HT3? Or.... play with the pump first and forego the turbo upgrade. I want a daily driver that has the power and speed when I need it. What to do, What to do?
opofus
Oh. I forgot...
Postby opofus » Tue May 13, 2008 11:20 am
I have a 91.5 2 wheel... all stock never messed with....
opofus
Postby Cschafer » Wed May 14, 2008 7:57 am
if your talking about the 07 turbo that's not an hx 35. There was a write up on one of the forums about adapting either an 06 or 07 turbo to a 12 valve. Sounds like they are a 60 or 62 compressor wheel and run a lot cooler then an hx-35. I'm not sure what is involved in making it work but it wasnt a bolt on. Do some homework on it and you might wind up with a great single turbo.
91 w250 wrecker
Cschafer
