by fergavs » Sun Jun 29, 2008 11:45 am
I did the exact sqame thing just before I tore the motor down this last time. I had been using the w/m for a long time (aprox 1 year) but didnt use it a lot because at higher rpm it kinda made the motor "crackle". Well after doing a tune up and adding as much timing as possible I took the truck for a test run and under full throttle/high boost flicked on the w/m. There was a terrible bang,bang,bang before I could let off. I popped the head gasket and decided to tear the motor down and do a bunch of stuff. Anyway I called Snow and asked why my w/m would be doing this. They instantly replied you have the nozzels installed backwards. I said no way I was sure I had double checked. The tech disagreed politely and said he was positive that was the problem. I asked why had it took so long to cause a problem? He said because of the heavy over fueling it probably was able to accept most of the water but with the extra timing.....POP!!! So is it posssible your other nozzel had been installed backwards? I was sure mine werent but when I checked
they were. Now I have a very nice mist vs a very bad squirt.
Sorry for the short story.
