Exhaust ?s
Exhaust ?s
Postby 92d250 » Wed Oct 01, 2008 1:36 pm
Would 6 inch from the turbo back be to big?
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby rbrettctd » Wed Oct 01, 2008 2:49 pm
Good luck gettting 6" downpipe in there. 4" is tight enough, 5" is a stretch.
Randy
rbrettctd
Postby PToombs » Wed Oct 01, 2008 5:06 pm
Most of the guys in the know say that you don't need anything bigger than 4", unless you're running big twins and bigger fuel.
Postby cummins king » Wed Oct 01, 2008 6:01 pm
you wont get a 6 inch in there, you cant even get a 5inch in there unless you custom fit it (i mean bash it with a hammer untill it fits)
you can put a body lift on there and it does help, but like RD said yo dont need 6 inch, 5 inch is to big unless you have big twins
CK
93 4X4 auto
cummins king
Postby fergavs » Wed Oct 01, 2008 6:41 pm
Bahh, to big!! :mad: Thats a matter of opinion. 6" is a litte much but if you have stolen a drainage culvert and want to use it as exaust I say why not. LOL. I run 5" and love it. I know I wont outgrow 5" and I would have with 4" in my opinion. One of the big mags did a test on different size exausts and came up with anything over 5" is a waste and for almost everyone 4" is fine. I figure if the turbo is 5" I'm gonna run 5". 2 cents.
fergavs
Postby 92d250 » Wed Oct 01, 2008 10:42 pm
ok thank you im prob gonna rin stock or 4 inch do to 5 inch then dual 6 inch stacks
92d250
Postby 92 cummins » Sun Jul 26, 2009 6:37 pm
there is no way you could fit a 6in downpipe it there, 4in is the biggest you can go. a 5in wouldn't even fit unless you banged it with a hammer.
92'W250,bullydog fuel pin,6in skyjacker with Mickey Thompson bead locks 16x12, 35's, custom 4in exhaust, K&N intake. 80k miles.
92 cummins
Postby DoWhat? » Sun Jul 26, 2009 8:00 pm
The only way i could figure to run 5" is out the fenderwell along the outside of the frame, then up through the bed... At least thats how my twins are going when i build them.
-91 W250 day cab 5 speed
strait pipe, monkey pump, big tires
-96 Ford F-250 PSD
strait pipe, big injectors, tunes
DoWhat?
Postby peobryant » Mon Jul 27, 2009 12:50 am
92 cummins wrote:there is no way you could fit a 6in downpipe it there, 4in is the biggest you can go. a 5in wouldn't even fit unless you banged it with a hammer.
Kinda dug this thread up... :lol:
Users browsing this forum: No registered users and 62 guests
