by bgilbert » Thu Dec 18, 2008 5:13 pm
I've never pulled a VE truck or VP truck. My theory is that you might be able to turn 4k rpm, but once a load is on the motor (sled behind you), it will pull down to the governed or max fueled rpm, which I would guess would be about 3k rpm. Dependant on where your max fuel point is, which I guess would be dependant on your setup (fuel, air, timing). My last trip to the dyno, with a poorly tuned truck, I made max power at 3k rpm. I'm pretty sure KTA has made 400+hp around the 4k rpm range. I'd have to dig out a dyno sheet, but I seem to recall making around 350hp at 4k rpm at one time.
Of course this might not have anything to do with sled pulling. I've just seen many stockish p-pump trucks, common rails and VP trucks pulling and just didn't have the ability to hold high rpm's down the track. My guess is the VE would act the same.
Maybe this isn't common knowledge, but a stock truck will turn 4k rpm with no load with the proper amount of throttle travel.
I think it will be hard to get any ideas on pulling 4k rpm down the track with a VE pump motor. My guess would be KTA will be the only one that can offer any advise or knowledge on the subject.
Or maybe stillsmokin and pulltilbroke can comment, I believe they are still pulling with VE pumps.
Bill Gilbert
