Getting ready to pull the trigger on my 3/8" fuel system and have some questions...
Here is were I'm at so far...
Got a draw straw...
http://www.vulcanperformance.com/Draw-S ... p/dsii.htm
Got a Walbro 392 and 20' of 3/8" Fuel line.
What kind of fitting (thread size) should I get for the pump? Any GOOD pics?
I need to get a pre-filter for the pump seeing as how I am going to lose the sock in the tank. Any Ideas? Some sort of screen is what I need I guess...
Also I'm by-passing the stock pump. I have a SBC fuel pump block off plate and I've heard it will work but would anything be hurt by just leaving the stocker in with out the lines hooked up? Would it burn up or something?
Gonna run this off a relay. Is there a key on power source under the hood I can use to trigger the relay?
Any other tips? Gonna start on this next week and would like to have everything I need.
thanks!!!
