by Ramrod90 » Wed Oct 21, 2009 7:15 pm
The reason I was going to go billet is because the 14mm h/r has such close tolerances, I figured all the extra support around it as well as the same expansion/contraction reactions would allow for high rpm without worrying about seizing the h/r and the extra strength should allow for the use of the 14mil. head and the 4mm cam-plate together. Am I wrong in thinking this? I would like it to handle the crank driven mechanical lp used on the Scheid puller. I think there are a lot of people who could utilize a gutted billet VE case to make more power than I could, I am just talking mainly about the case itself. Instead of just making an identical VE case, what are the internal modifications that could be done to promote the production of power/cc's/longevity of the pump itself under those conditions.
Ramrod90 on Wed Oct 21, 2009 7:25 pm, edited 1 time in total.
90 w250 LE, pump turned up, 4" turbo back, I/C conversion, 366 GS, DennyT pin, 6x18's, BHAF, soon to come... 6" stacks and built head.
Diesel is more than a fuel... it's a way of life
