What size Turbo Housing
Postby BuckHunters92 » Fri Nov 13, 2009 5:35 am
Is there any way to identify the size of your turbo housing without taking it off and looking inside it. I took my truck to a Diesel Performance shop today to see what mods they could do without breaking the bank. Its a 92 W250, auto 4x4, w/intercooler. They drove it and said it spooled up to quickly to have a 21.m. housing. They said there is no way to tell the size without taking it off and looking in it. Is this right, or is there some other way to tell.
92 W250, Auto, 4x4, ext cab, Am. Racing, Baja 16x8 wheels, BF. Goodrtch T A's 285x75x16, cold air intake.
BuckHunters92
Postby unixcowboy » Fri Nov 13, 2009 11:48 am
With the auto you probably have the 18.5 cm.
With an auto you don't need to re-spool at every shift so that's a pretty good size. Plus it helps keep the egt's down.
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby 921stgen » Fri Nov 13, 2009 3:27 pm
92 trucks have a 21cm unless someone has changed it, but I couldn't see someone changing it and not the turbo.
921stgen
Postby PToombs » Fri Nov 13, 2009 6:36 pm
Why not? I did it that way. A newbie starting out doesn't know as much, so that's an easy upgrade. I just wanted quicker spool at 1st. Then I started to learn more and siht happens. :lol:
Postby Richie O » Fri Nov 13, 2009 6:38 pm
I was so new I had someone else change mine to a 16cm. :shock:
Postby james-93-12valve » Fri Nov 13, 2009 7:23 pm
wat size would a 93 5spd have
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby RumbleFish » Fri Nov 13, 2009 7:45 pm
18.5cm
Postby T.winegar » Mon Dec 21, 2009 12:08 am
so a 16cm on an 89 with the automatic isn't good?
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
Postby CHEMMINS » Mon Dec 21, 2009 12:48 am
Its fine, it keeps your spool fast. As small as I would run though.
91 Chev CC 4x4 1 ton w/93 12v g360/205/d60/70.
|^^^^^^^^^^^^^|||__
|---CHEMMINS------ |||||";\,___.
|_..._...______===|=||_|__|...,]
CHEMMINS
Postby dpuckett » Mon Dec 21, 2009 7:47 am
Look on the engine data plate. IF it's a 1351 CPL, it'll likely have a 21cm housing; if it's a 1579 CPL, it'll be a 18.5 stock. They switched CPLs sometime between April and June 92.
And, there is no such thing as "spooling too fast to have a 21cm housing." If the fuel has been tuned right, it can still have some get up and go. Maybe not like Bill's 89, but there are several things that can be done to help spoolup while keeping the turbo and housing the same.
Take a mirror and look on the back side of the housing. It will have an 18.5 or a 21 somewhere on it. That is if it's stock, which is a crapshoot at this point.
Dan
