nitrous help
nitrous help
Postby rattlebox93 » Thu Sep 16, 2010 11:26 pm
i am new to the nitrous thing i already had a wet kit my cousin gave me so i went and bought a dry nozzle or needle i guess some call it?.... what jet are you guys running in your setups? the guy sold me a .047 and said it should be around 75hp i figured that to be a fairly safe starting point.... also how far from the inlet of the turbo are you putting your nozzle's? thanks a ton! dj
rattlebox93
Re: nitrous help
Postby JQmile » Thu Sep 16, 2010 11:42 pm
Two .135 jets :D
To be fair, my bottle pressure is low though. I started out back in the day with a 0.075 jet which would be ok on a gas rig, but that was barley worth 40hp on my rig. Bottle pressure is huge also, you'll gain more power through bottle pressure than you will upping the jets practically. Your bottle pressure should be at about 900-1000psi, any more than 1,200 and your solenoids might not work. Use a bottle heater to get the pressure that high. Nitrous isn't that scary, just make sure you have at least 15psi when you hit it, and don't overspeed your turbo!
Edit: All my nozzles are post turbo in the intake horn area.
JQmile
Re: nitrous help
Postby Douglas » Fri Sep 17, 2010 5:36 am
hey-Hey!!!,
I saw a neat install on a propane powered Caddy that ran the nitrous nozzle in the turbo housing( two separated by 180 degrees) to blow on the compressor wheel to reduce lag. not sure it would be worth the trouble on our big TDI's though.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: nitrous help
Postby rattlebox93 » Fri Sep 17, 2010 7:52 am
hey jason
what nozzles are you using? i have one NOS blue fan nozzle so you have both nozzles in the intake horn? i have cooler tubz what should i do? buy another and put one in the front and one in the back facing the engine using a y and start out with some .095 jet or so? what kind of hp u think that would be i have a he351cw 6x16's 4200 spring phlp press reg ported head ported ind manifold that drops out like a commonrail and the exhaust housing has been opened up the the size of the gasket at the inlet im just new to nitrous i cant say im scared i just dont want to over do it rite off the bat and break a charger
rattlebox93
Re: nitrous help
Postby Cschafer » Sun Sep 26, 2010 4:32 pm
Not sure on the wastegate size of the 351cw. overspeeding might be a problem with much nitrous. I've ran two small nos solenoids from a plate kit that didnt have jets they threaded in with 1/8 pipe. I ran them wide open into the cac tube. first shot was about 80 hp if i remember. Nitrous is a blast with these motors! try around .090 jet and see what happens hit it at 15psi and watch your boost guage!
91 w250 wrecker
Cschafer
Users browsing this forum: No registered users and 71 guests
