366 install problem
366 install problem
Postby danc » Wed Nov 24, 2010 4:20 pm
I installed a 366 spring and fired up the the beast. The truck idles fine but stall when I give it throttle with out reving up. Any ideas what I did wrong??????
1993 club cab 2wd, auto,s300,5x14s,BHAF,powertrax,denny t, Carter 100gph,specrite tc, built 518,tampered pump,and a new headliner.
danc
Re: 366 install problem
Postby zach kinney » Wed Nov 24, 2010 7:55 pm
well i never had a problem doing mine. but i would pull it apart and make sure you got the index on the throttle right iv heard that can cause alot of problems.
1990 dodge w250 non i/c 727, shift kit and deeper tranny pan, custom cold air, denny t fuel pin, star wheel turned down, fuel screw 2 turns, 5in stacks, 3200 spring, timming advanced 1/8", gauges, coolertubz, valet switch .
zach kinney
Postby Deathrod » Fri Nov 26, 2010 10:51 pm
The fuel pin (the actual pin that rides on the ramped part) got stuck in when i did mine....wouldnt even start til i figured it out...but probably the indexing like he said
Deathrod
