Just a little more . . . . .
Postby BC847 » Tue Jan 20, 2015 5:18 pm
fatty wrote:Can you be a little more specific on the new shocks you put on? I'm going to replace mine here soon and was going to do Bilsteins, but not if these pthers are better.
It was recently pointed out to me our truck's suspension is designed to work with basic hydraulic shocks. When you consider the pressure one has to apply to compress a gas-charged shock, you might recognize the 40 ~ 50 lb preload the shocks present (each) to the suspension. That throws things off.
I am NOT suggesting the gas-charged shocks (and the benefit the technology presents) are plain wrong. It's just that, like everything else, it depends on what you expect/want. ;)
I just removed my Bilsteins and replaced them with some ProComp ES3000. As such, my ride is not quite as "Stiff". There's definitely a reduction in the roar in the steering-wheel presented by a rough black-top road (rough as in larger pea-gravel adhered to the surface).
The change accomplished my goal of smoothing the ride with the added bonus of less road noise. :)
For my 1993 W250 CC, I used two EXP-321506, and two EXP-329503 (all four are standard hydraulic) as purchased from Summit @ $ 41.99 ea.
EXP-329503: http://www.summitracing.com/parts/exp-329503/overview/model/w250
EXP-321506: http://www.summitracing.com/parts/exp-321506/overview/
At the end of the day, the truck still rides like a straight-axle /leaf-spring truck. :shock:
Postby BC847 » Tue Jan 20, 2015 5:22 pm
DMan1198 wrote:Care to divulge the details on the spinny things, and other bits?
Nothing in stone as of yet. Considering the suggestions posted thus far, and the money potentially spent, I'd be smart to carefully consider it all. . . . . . blah, blah . . .
I have no clue right now. :lol:
Postby RCCUMMINS89 » Tue Jan 20, 2015 5:23 pm
I've been talking to Thuren about shocks and spring combinations. I was told that on a leaf sprung truck, "white body" shocks will ride much, much better if set up right.
Postby slowdiesel » Tue Mar 03, 2015 1:13 pm
I like the s478 6 blade with a super b..
1984 D100 Ve-Twins.
Special Thanks Mayer Farm Equipment
slowdiesel
Postby Stomp » Thu Apr 02, 2015 7:45 pm
Thought I had better keep an eye on this post. Good info shared by all. I always wanted to change out my dinosaur BTH3B/26 but was always too cheap. I know my GT4202 sure likes to light off quick under my stock turbo on my 3rd gen.
Stomp
93W250CTD,7 isspro gauges,Piers stage 2+ ported/polished/o-ringed head,ARP 12mm studs,ATS 3 piece,Custom twins by Brad @ Ponci's Diesel Center BTH3B/26 w/Piers HX40/16, custom 4"exhaust/ intake by Brad@ PDC,370's,KTA-Special 14mm Head/Rotor
Stomp
Postby RCCUMMINS89 » Thu Apr 02, 2015 8:18 pm
Anyone ever put in the effort on the Garret calculator stuff?
Also, does anyone know how to calculate pump cc to the brake specific fuel consumption?
Postby DMan1198 » Fri Apr 03, 2015 8:21 pm
I tried the calculator once. I think my goals were too lofty though as it didn't have any suggestions for 1200hp
Postby Remps » Fri Apr 03, 2015 10:35 pm
I play around on it sometimes, it's amazing how much intake temps affect pressure ratio needed to get necessary air for a given output. I just use .37 bsfc.
Postby Remps » Sat Apr 04, 2015 4:38 pm
Btw Dman, it will spit out a recommendation for 1200 hp, but peak power has to be closer to 4k rpm.
Postby DMan1198 » Sat Apr 04, 2015 5:14 pm
I'm pretty sure I was asking for 5k, but after more research I've figured out a gtx4718r or gtx5018r would reach the goal with air to spare. putting a gtx4088r or gtx4294r would help a lot with response over an 88mm single
Postby Tacoclaw » Sat Apr 04, 2015 5:45 pm
Air to spare = wasted inertia/area.
That's the whole point of sizing them. :P
Postby DMan1198 » Sun Apr 05, 2015 4:17 pm
Air to spare meaning it should run decently cool at the desired power level, and should I feel like it more fuel can be added to make even more power. A bit of the problem with Garretts is to get a big enough turbine wheel to properly deal with exhaust flow you sometimes end up having to run quite a large compressor. Unlike the Borg chargers where you can get a huge range of compressors with the same turbine
Postby Tacoclaw » Sun Apr 05, 2015 6:51 pm
Gonna need to add a bit more fuel after your 1200hp goal? :lol:
There's pages of setups on CompD skirting the 1k range and above, I'm sure any pick of them would suit your build just fine. The Garrets are awesome but they just don't seem to be diesel-oriented. Why pigeonhole yourself in with them?
Postby DMan1198 » Sun Apr 05, 2015 8:12 pm
Why not? Everyone always likes a little more
I was just using Garret's as an example since Eric brought up Garret's calculator. As nice as they'd be I'll likely just go with a pair of Borg chargers. The more I think about it the more an s400/s400 setup appeals to me even for the 5.9 (I might go to a 6.7 bottom end at some point just for the extra spooling capabilities) which will make the flexibility of an s400 secondary that much more convenient
Postby BC847 » Mon Jul 04, 2016 5:34 pm
Derp! :shock:
