Remps wrote:Mike 8061, you should look into a HP piston pump with a pressure regulator if you want to stay mechanical. Should keep up with a 12 mm IP, and if it doesn't you could tee in a holley black with a check valve to the outlet of the piston pump. That way you'd always have a mechanical fuel supply. Richie, you must have more than 301 hp with the 62/71/14? Isn't that number with the gds h1c?
I have not changed the fuel settings for years. The best was 301 hp with the stock tires on. I switched to bigger tires and lost about 20 horses. I have not dynoed with the HTT yet, but don't suspect I will gain much power as I have not added any fuel. I am seeing the same boost as I was with the GDS, and a little cooler egt's. ( though, not much cooler ) If I got back to 300 horses with my bigger tires and no changes I would be surprised. I am a low torque fan, so I have left the timing stock. I am at 730 foot pounds even when I am under 300 horses.
