top turbo shootout
Re: top turbo shootout
Postby fatstack » Fri Feb 24, 2012 2:21 pm
Dang. Do you think it will be worse than stock?
89 d250 getrag ripper, pump maxed,timed to the head,pull cable shutoff, 354 spring, straight pipe, 4:10 gears, in the shop: he351cw and 3:07 gears
90 w350 nv4500,ic motor, stock, 5" stack w a western hauler on back
fatstack
Postby oldestof11 » Fri Feb 24, 2012 3:01 pm
No, it has a bigger compressor and turbine wheels. The housing size with that turbine will flow well for a stock injector truck. You will be able to keep on top of it and cool effectively. The HY35 on the other hand, is one that more cool air is minimal and the turbine/housing combo won't flow as well.
Postby fatstack » Fri Feb 24, 2012 4:54 pm
Hell yeah!
fatstack
