Next was a M&H M2 fuel pin,it is a nice up grade. I also bottomed the star wheel and screwed the smoke screw down flush with its jamb nut. That made the truck pep up more but brought the smoke on fairly good. WOT had it smoke a greyish cloud. Not bad,just noticeable.
Now I have installed the 366 spring and 7x10 injectors. With the afc set up above,I could black out the road behind. Now the afc has been tightened up and my max boost is around 38ish. Least that's where I let off the throttle
All that is with the fuel screw set factory.
Far as turbo upgrade,I like the GDS 60mm inducer I have seems to keep the egts in check with my other upgrades.
