Performance mods for a rock buggy? BACK FROM THE DEAD!
Re: Performance mods for a rock buggy?
Postby oldestof11 » Wed Apr 11, 2012 2:12 pm
I would put in at least new headbolts torqued down to 125ft lbs or even 130ft lbs. That should hold.
Postby PToombs » Wed Apr 11, 2012 5:26 pm
Along with a new head gasket!
Postby Deathrod » Wed Apr 11, 2012 8:51 pm
Someone else would probably know better then me....but don't you need #60 lb valve springs to run those high rpms?
Deathrod
Postby oldestof11 » Thu Apr 12, 2012 4:10 am
110.
I can get pictures from a p-pump 12sec drag truck that lost OD and had just 60lbs springs. The exhaust kissed each piston when he revved that motor to 4400 rpms....
Postby Jeep-hauler » Thu Apr 12, 2012 9:05 am
oldestof11 wrote:110.
110's eh? This could get expensive. :shock: Maybe I should just be happy with a 3200 spring until I get it sorted out.
'51 Power Wagon VE Cummins project.
'92 W250 -Got it cheap, it runs, it's ugly, it's a parts truck
'93 W250 -tweaked pump, 4" exhaust, NV 4500HD 5-speed. Jeep tow rig, daily driver. Sold.
Jeep-hauler
Postby oldestof11 » Thu Apr 12, 2012 3:26 pm
Cummins Performance Parts has 110's for just under $500...
Postby ellis93 » Thu Apr 12, 2012 4:22 pm
oldestof11 wrote:Cummins Performance Parts has 110's for just under $500...
"Just" 500$ huh :lol:
You just made that sound like 5$ Jon :lol:
Postby Jeep-hauler » Thu Apr 12, 2012 5:09 pm
Yeah, pocket change. ;)
I don't know, the 4k spring like a slippery slope. Heavier valve springs, maybe new retainers, might as well buy heavy-duty pushrods while your at it :lol: .
How well does the VE fuel at that RPM? Who here is running one?
I think I might take some of the earlier advice and keep it mild at first and see if the drivetrain stays together, then start hot-rodding it.
Jeep-hauler
Postby PToombs » Thu Apr 12, 2012 5:46 pm
With all the torque of a cummins down low, why do you think you need to wind the snot out of it? I understand if you need to stab it quick and get over a rock or something, but I just don't see the need for a 4k rpm truck. That makes things very expensive in a cummins, if you need that kinda rpms, put in a small block chevy or something.
Postby AHineman » Thu Apr 12, 2012 5:52 pm
I agree with Pete. Torque and gearing are where its at. Winding it up that far puts you past your peak for both horsepower and torque anyways.
Postby oldestof11 » Thu Apr 12, 2012 6:45 pm
With rock crawling, torque can help getting started in 3rd gear but the quick stab and high RPM's are needed to launch up the rock.
Torque is not going to help climb this wall...
http://www.youtube.com/watch?v=wir8f8KN ... re=related
Postby Tacoclaw » Fri Apr 13, 2012 6:15 am
You can get wheel speed with gearing, you don't have to wind the engine up that high. It'll be a tough dance to pick the perfect ratio to compliment the Cummins. :/
Postby Jeep-hauler » Fri Apr 13, 2012 7:18 am
I don't mind RPM discussion at all. I'm listening to all ideas, that's why I started the thread.
That said, I think gearing is going to be key in making it work. I've ran 4.88 and 5.13:1 ratios in my Jeeps with 35-37" tires, so I'm thinking 4.10's or 4.56 gears with 39-40 tires should work with the Cummins torque.
And I don't wheel like these Southern guys. :mrgreen: We call that "rock bouncing" not crawling.
Jeep-hauler
Postby oldestof11 » Fri Apr 13, 2012 2:09 pm
Also, the less gearing in the axles means more torque placed on the trans and transfer case. :?
I would go 4.56's or 4.88's.
The fact that you have a manual is what is hard. With an auto, you can still have 3 or 4 forward gears with no disconnect of power transmission. With a clutch, if you need another gear, you have to disconnect the engine to get another one...
I would not really do head studs because the gearing will be helping to keep cylinder pressures down.
Postby Deathrod » Fri Apr 13, 2012 9:33 pm
Well whenever you get it done bring it down to the Hammers!!! That body could use a few major dents
Deathrod
