KTA wrote:40CC'S AT RPMS below 1500, no more fuel or 0cc's for rpms over 2000. So if you are looking for more smoke it will help, more power it probably won't unless you run very small injectors and a turbo setup that makes full boost at 1200-1500rpm.
RCCUMMINS89 wrote:I remember you talking about drillint out the fill port..... forgot about it. So when will you best testing this pump? Also does that pump have the "custom" delivery valves? Curious on if you did multiple mods or just one at a time to confirm.
oldestof11 wrote:RCCUMMINS89 wrote: Look up how the VP works you you might get an idea on what I am going to try with our DVs.
AHineman wrote:Non intercooled don't flow 40cc more. Some more, but not 40cc. A custom cut set can.
BC847 wrote:oldestof11 wrote:RCCUMMINS89 wrote: Look up how the VP works you you might get an idea on what I am going to try with our DVs.
I'm pitiful.![]()
Can you direct me to a link to said info?
Smokem @ CompD wrote:VP44's don't have delivery valves.
