Low-compression pistons on the street?
Postby GPSMatt » Tue Dec 04, 2007 11:05 pm
KTA wrote:I get my marine pistons from cummins. 8)
any one got a P/N for hte marine pistons
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby dpuckett » Fri Dec 07, 2007 5:38 pm
Find someone with a marine 5.9 and get the engine serial number and CPL from it. Then you can go to Cummins and see what they got.
DP
Postby ford69557ci » Fri Dec 07, 2007 6:47 pm
well who on here has a marine 5.9 ???? i would like a set of them for my project. i really dont see the advantage of aftermarkets piston cuz the cummins ones seem to hold of power.
ford69557ci
Postby GPSMatt » Fri Dec 07, 2007 7:12 pm
i here that there is some with teflon coated skirts. its deff the cheap way out on some low comp pistons the arias ones are like 1500 or more i think
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Fri Dec 07, 2007 7:57 pm
factory coate ones??? that would be sweet i want the part number for those
ford69557ci
Postby bgilbert » Fri Dec 07, 2007 8:04 pm
Serial number 45432843 CPL 2208 for 370HP marine engine.
Bill Gilbert
bgilbert
Postby ford69557ci » Fri Dec 07, 2007 8:10 pm
thanks for the numbers i am goin to order a set tommorrow
ford69557ci
Postby GPSMatt » Fri Dec 07, 2007 9:11 pm
any one kno if those are the teflon coated ones? thanks for the p/n
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Fri Dec 07, 2007 9:15 pm
i will find out monday my local cummins is closed on weekends
ford69557ci
Postby KTA » Sat Dec 08, 2007 7:59 am
3800756 Is the piston kit part number for 15.3:1 teflon coated skirt pistons.
Postby Begle1 » Sat Dec 08, 2007 9:21 am
What's the benefit to teflon coating?
Postby KTA » Sat Dec 08, 2007 9:47 am
Less piston slap and less skirt scuffing.
Postby ford69557ci » Sat Dec 08, 2007 9:54 am
Once again KTA is the man. thanks for that number
ford69557ci
Postby GPSMatt » Wed Dec 12, 2007 11:10 am
ford69557ci wrote:i will find out monday my local cummins is closed on weekends
got a price on em yet?
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Sat Dec 15, 2007 2:07 am
no i have not had a chance to call them i have been retarded busy with gettin some chassis work done on my s10
ford69557ci
