You need to compare the lever assemblies between the two pumps. The lever assembly is the linkage assembly that connects the governor spring & "top hat" piece down to the control collar. In a fixed speed pump application the governor weights are different according to Bosch.
Start reading at page 19 in http://www.dieselbookmarks.com/bombers/VEPump.pdf
Save a copy and print it out for future reference.
