8 hole injector
Postby JD730 » Wed Nov 07, 2007 5:43 am
PToombs wrote:Higher pop pressures aren't good. Stock pressures on modded injectors are what you are after. The VE doesn't like high pop pressures, I've read it's not good for the innards. :mad:
So true. They really don't like P-pump pop pressures, in fact they don't even run very well. Kinda surprised it ran as well as it did.
Mike
The "Rattle Box"
JD730
Postby ford69557ci » Fri Nov 09, 2007 1:37 am
well i am not quite close to the p pump pop just slightly over stock i have seen p pump injectors on a ve and it went for about 1000 miles and hat a ip failure.
ford69557ci
Postby DTanklage » Fri Nov 09, 2007 11:00 am
why would you want more pop pressure?
the pods i have are set up at a slightly lower pop pressure
(100 lower than stock)
you sure yours are set up higher?
DTanklage
higher pop off
Postby roxxx » Fri Nov 09, 2007 12:19 pm
You get better fuel atomizing at higher pop off
I don’t know much about 1 st gen VE but with the VP pumps the better pop off the better the burn and less smoke and more power. I have found a injection and pump shop that's going to give me a bit of guidance in the injection and pump department .I plan on getting a set of the 370's, They are quiet interested in the claim that I can get 70 hp 1ST gen injectors, we are looking into trying to see if there is any marine VE pump or Industrial VE pumps that will bolt up which would mean might be able to get more pressure
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby DTanklage » Fri Nov 09, 2007 4:26 pm
from everything i have heard about that vp-44 if i was you i would be looking at converting to a p-7100
like all of us should be doing!
DTanklage
Postby ford69557ci » Fri Nov 09, 2007 4:30 pm
when i get the other engine done i am doin a 13 mm p pump but with the original engine i wanna push the ve limits as far as possible :evil:
ford69557ci
Postby KTA » Sat Nov 10, 2007 6:50 am
I make high end P-pump hp with my VE and it was a hell of alot cheaper! :roll:
Postby DTanklage » Sat Nov 10, 2007 9:11 am
oh
i am sorry...
i thought 600ish was middle of the road for one of those pumps
or about what a really good pump would make if fully detuned
DTanklage
Postby Begle1 » Sat Nov 10, 2007 9:19 am
KTA wrote:I make high end P-pump hp with my VE and it was a hell of alot cheaper! :roll:
It's cheaper to get 600HP out of a VE than 600HP out of a P-pump?
Isn't "high end" P-pump power in the 700, 800+ HP range? And that's relatively streetable; aren't the super modified ones are well over 1000?
Postby DTanklage » Sat Nov 10, 2007 10:38 am
800 streetable hp?
i doubt it
but i think you can put less than a grand into a p-7100 and end up with a pump that would supply 800+ hp worth of fuel
something you could never do with a ve pump, no matter how much money you threw at it
you could detune it (slide the plate to the rear) and still be around 600 streetable hp
when you 'need to'... slide the plate forward and watch out!
down the road that is how i want to set mine up
pretty sure josh is doing that right now...
DTanklage
Postby ford69557ci » Sat Nov 10, 2007 11:27 am
i know of a place to get a 14mm custom pump with or without a gov for around 1600 p pump style with 14mm p&b and 14mm cam lift i think they said it could move like 1200 1300 cc if there was the air that would make some power. and it has a warranty
ford69557ci
Postby Begle1 » Sat Nov 10, 2007 11:45 am
DTanklage wrote:800 streetable hp?
i doubt it
Well, 800HP is about 500HP with a simple valet switch...
Postby DTanklage » Sat Nov 10, 2007 10:34 pm
isnt 1200cc gettin close to like 1400 hp?
DTanklage
Postby KTA » Sat Nov 10, 2007 11:39 pm
1200cc is more like 2400hp. I have seen 1400+fwhp done on a 5.9 cummins with a 800cc pump, and that isn't burning anywhere near all the fuel. My pump is only 330cc. There are not nearly as many high hp 12v running around as you all seem to think. Look at the dyno event from Scheids only 1 12v cracked 600rwhp on fuel, and it has a fully built motor, but it is a single turbo and a stock maxed out p-pump. The thing I hate about the maxed out big fuel p-pumps is the governor control is horrible.
Postby Begle1 » Sun Nov 11, 2007 9:09 am
KTA wrote:The thing I hate about the maxed out big fuel p-pumps is the governor control is horrible.
How so?
